Hand Build, Combine, Split, and Modify Elements
Stitch two unconnected meshes by adding elements between them, split elements at weld locations, and combine and split elements to fix connectivity in the transitional area between fine and coarse mesh areas.
For more information on building, combining, splitting, and modifying elements, see the Edit Element Panel topic.
