Split Plate, Solid, and Hexa Elements
Use the Split panel to split plates or solid elements. In addition, hexa elements can also be split using a technique that moves progressively through a row of elements in the model
For more information on splitting plate, solid, and hexa elements, see the Split Panel topic.
