Istf |
Interface stiffness
definition flag.
- =0
- Set to 1000.
- 2
- Interface stiffness is the average of the master and
slave stiffness.
- 3
slave stiffness.
- 4
- Interface stiffness is the minimum of the master and
slave stiffness.
- 5
- Interface stiffness is the master and slave stiffness in
series.
- = 1000 (Default)
- Interface stiffness is only based on the master side
stiffness.
(Integer)
Igap |
Gap/element option flag.
- =0
- Set to 1
- =1 (Default)
- Variable gap varies according to the characteristics of
the impacted master surface and the impacting slave
node.
- =2
- Variable gap + deactivating slave nodes if element size
< gap value, in case of self-impact contact similar
to Irem_gap=2 for
/INTER/TYPE7.
- =3
- Variable gap + size of the mesh is taken into account to
avoid initial penetrations.
(Integer)
Ishape |
Flag defining the shape of
the gap along free edges.
- = 0
- Set to 1.
- = 1 (Default)
- Square gap.
- = 2
- Round gap.
Irem_i2 |
Deactivating flag for the
slave node, if the same contact pair (nodes) has been defined in
interface TYPE2.
- =0
- Set to 1
- =1 (Default)
- Slave nodes in /INTER/TYPE2 tied
contacts are removed from this contact.
- =3
- No change to slave nodes.
Idel |
- =0
- Set to 1000
- = 1
- When all the elements (4-node shells, 3-node shells,
solids) associated to one segment are deleted, the
segment is removed from the master side of the
interface. It is also removed in case of explicit
deletion using Radioss
Engine keyword /DEL in the Engine
file.
- Additionally, non-connected nodes are removed from the
slave side of the interface.
- = 2
- When a 4-node shell, a 3-node shell or a solid element
is deleted, the corresponding segment is removed from
the master side of the interface. It is also removed in
case of explicit deletion using Radioss Engine keyword
/DEL in the Engine file.
- = 1000 (Default)
- No deletion.
Igap0 |
Gap modification flag for
slave shell nodes on the free edges.
- =0
- Set to 1000
- = 1
- Set gap to zero for the slave shell nodes.
- = 1000 (Default)
- No change.
(Integer)
Inacti |
Initial penetration flag.
- =0
- Set to 1000
- = -1
- All initial penetrations are taken into account.
- = 5
- The master segment is shifted by the initial penetration
value
- If
, then
, where
is the initial
penetration.
- = 1000 (Default)
- Only tiny initial penetrations (1.0e-08) will be taken
into account.
(Integer)
