/DEFAULT/INTER/TYPE7
Block Format Keyword Defines default value for TYPE7 interfaces.
/DEFAULT/INTER/TYPE7 | |||||||||
Blank | |||||||||
Istf | Igap | Ibag | Idel | ||||||
Blank | |||||||||
Irem_gap | Irem_i2 |
Blank | |||||||||
Inacti | |||||||||
Iform |
Istf | Interface stiffness
definition flag. 5
For SPH, only Istf=0 and =1 are available.
(Integer) |
Igap | Gap/element option flag.
13
(Integer) |
Ibag | Airbag vent holes closure
flag in case of contact.
(Integer) |
Idel | Node and segment deletion flag.
(Integer)
Note: Idel=1 and -1 have a
higher CPU cost when compared with Idel=2 and
-2.
Irem_gap | Flag for deactivating
slave nodes if element size < gap value, in case of self-impact
contact. 24
(Integer) |
Irem_i2 | Flag for deactivating the
slave node, if the same contact pair (nodes) has been defined in
interface TYPE2.
Inacti | Deactivation flag of
stiffness in case of initial penetrations.
(Integer) |
Iform | Friction penalty
formulation type. 20
21
22
(Integer) |
