Ignore |
Flag to ignore slave nodes
if no master segment found. 13
14
- =0
- Set to 1000.
- =1
- Slave nodes with no master segment found during the
Starter are deleted from the interface.
- =2
Starter are deleted from the interface, new calculation
for
dsearch,
if
dsearch=
0.
- =3
for
dsearch,
if
dsearch=
0.
- =1000 (Default)
- No deletion of slave nodes.
(Integer)
Spotflag |
Spotweld formulation flag.
4
5
6
7
8
12
- =0
- Set to 4, if /CAA is
used.
- Set to 5, if /CAA is
not used.
- =1
- Formulation is optimized for spot welds or rivets.
- =2
- Same formulation as standard formulation. Required when
using hierarchy levels. Not compatible with nodal time
step, /DT/NODA/CST.
- =4 Default, if /CAA
is used.
- Rotational DOF are not transmitted, if shells are used.
Not compatible with nodal time step
/DT/NODA/CTS.
- =5 Default, if /CAA
is not used.
- Standard formulation.
- = 20, 21,
22
- Formulation with failure. Not compatible with nodal time
step, /DT/NODA/CST. The stress is
computed for each slave node according to the
"equivalent" surface around the node. The equivalent
surface is defined accordingly:
- =20
- Surface computed using shell and brick faces
attached to the node.
- =21
- Surface computed using only the shell attached
to the node.
- =22
- Surface computed using only the brick faces
- =25
- Penalty formulation (not recommended). 19
- =27
- Kinematic formulation similar to Spotflag =5 with an automatic switch to penalty formulation
when incompatible kinematic conditions occur. 20
- =28
- Kinematic formulation similar to Spotflag =1 with an automatic switch to penalty formulation
- =30
- Formulation with cubic curvature of master segment. Not
compatible with nodal time step,
/DT/NODA/CST.
(Integer)
Isearch |
Search formulation flag
for the closest master segment.
- =0
- Set to 2.
- =1
- Old formulation (only used for previous version).
- =2 (Default)
- New improved formulation.
(Integer)
Idel2 |
Node deletion flag. 9
10
16
- =0
- Set to 1000.
- =1
- Kinematic condition is suppressed on the slave node,
when all elements linked to the master segment are
deleted. (The slave node is removed from the
interface).
- =2
- Kinematic condition is suppressed on the slave node, if
the master element is deleted. (The slave node is
removed from the interface).
- =1000 (Default)
- No deletion.
(Integer)
Istf |
Interface stiffness
definition flag. 17
Only used with penalty formulations ( Spotflag= 25, 27 or
28)
- =0
- Set to 2.
- =1
- Penalty stiffness is the master stiffness.
- =2 (Default)
- Penalty stiffness is the average of the master and
slave stiffness.
- =3
- Penalty stiffness is the maximum of the master and
slave stiffness.
- =4
- Penalty stiffness is the minimum of the master and
slave stiffness.
- =5
- Penalty stiffness is the master and slave stiffness
in series.
(Integer)
