/GRNOD/GENE
Block Format Keyword Generate a group of nodes by listing the first and last node IDs in the range.
For each list, enter first node and last node (any number of lists may be input, up to 5 per Line). All nodes between first_ID and last_ID are selected.
/GRNOD/GENE/grnd_ID/unit_ID
grnd_title
first_ID1 last_ID1 first_ID2 last_ID2 first_ID3 last_ID3 first_ID4 last_ID4 first_ID5 last_ID5
grnd_ID Node group identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
grnd_title Node group title
first_ID1, last_ID1,...first_IDn, last_IDn List of first and last node identifiers
(Integer)
  1. Node groups are used to define slave nodes of rigid walls, interfaces, rigid bodies or nodes to which a load is applied, like a concentrated load or a fixed velocity.
  2. Nodes are stored in this order. For all other input types, nodes are sorted.
