/GRNOD/PART
Block Format Keyword Describes the node part groups which belong to given parts.
/GRNOD/PART/grnd_ID/unit_ID | |||||||||
grnd_title | |||||||||
item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
grnd_ID | Node group
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
grnd_title | Node group
item_ID1, item_ID2,..., item_IDn | List of part
identifiers (Integer) |
- Node groups are used to define slave nodes of rigid walls, interfaces, rigid bodies or nodes to which a load is applied, like a concentrated load or a fixed velocity.
- If item_ID is a negative number, the item number is deleted from the group.
- Nodes are stored in this order. For all other input types, nodes are sorted.
