/GRNOD
Block Format Keyword Node Groups
Input Type Keywords: Node Group
- Keyword
- Input Type
- /GRNOD/BOX
- Box
- /GRNOD/GEN_INCR
- Generate list by increment
- /GRNOD/GENE
- List of nodes with generation
- /GRNOD/GRBEAM
- Beam group
- /GRNOD/GRBRIC
- Brick group
- /GRNOD/GRNOD
- Node groups
- /GRNOD/GRQUAD
- Quad group
- /GRNOD/GRSHEL
- 4 node shell group
- /GRNOD/GRSH3N
- 3 node shell group
- /GRNOD/GRSPRI
- Spring group
- /GRNOD/GRTRUS
- Truss group
- /GRNOD/LINE
- List line groups
- /GRNOD/MAT
- Material
- /GRNOD/NODE
- List of nodes
- /GRNOD/NODENS
- Unsorted node numbers
- /GRNOD/PART
- Part
- /GRNOD/PROP
- Property
- /GRNOD/SUBMODEL
- Submodel
- /GRNOD/SUBSET
- Subset
- /GRNOD/SURF
- Surface
- A node group is a set of nodes. It can
be defined explicitly by a list of:
- nodes
- entering a first and last node ID range which defines the group
- submodels (all nodes belonging to the listed submodel are included)
- submodels (all nodes defined by /NODE or /CNODE in the listed submodel are included)
- subsets or parts (all nodes belonging to the listed subset/part are included)
- property sets or materials (all nodes belonging to an element having those Property Type's/MID's are included)
- groups of nodes
- element groups (all nodes connected to those elements are included)
- a box (all nodes within a defined box are included)
- an unsorted node list: same as list of nodes, but the nodes are not sorted (only needed in /INTER/TYPE8 and /XELEM option).
- Node groups are used to define slave nodes of rigid walls, interfaces, rigid bodies or nodes to which a load is applied, like a concentrated load or a fixed velocity.
- Nodes are stored in this order. For all other input types, nodes are sorted.
