Altair HyperMesh 2020.1 Release Notes
3D Meshing
Enhancements
- Volume meshing quality enforcement
- Improved volume meshing optimization capability to enforce user defined size and quality. In order to enforce quality and sizes during the optimization stage, mesher will also move surface mesh nodes. Due to this capability criteria like minimum height can be enforced as well.
Composites
New Features
- Composite Browser
- Browser added for composites focused modeling. Existing composites entities and related modeling tools have been consolidated at this location.
- Composite Stress Toolbox
- Initial implementation of a composite stress toolbox has been integrated
with the Composite Browser. CLT based calculations are available from
the context menu for material, ply, laminate and zone entities. It is
intended to be a replacement and then expansion of existing
HyperLaminate functionality.
- Materials/Plies – engineering constants, 2D/3D material matrices calculated
Enhancements
- Zone Calculation
- Zones of constant thickness within a laminate are now automatically calculated as composite models are created and edited and are displayed in the Composite Browser. Zone generation requires a laminate in which all plies have an assigned shape. This is an initial implementation; many enhancements are planned in future releases.
- Ply Instancing
- Ply instancing is now available from the right click context menu of the Composite Browser. The operation will generate n-instances of the main ply. The instance plies will automatically update as data in the main ply is edited.
Connectors
Enhancements
- Two links only option
- New option “Two links only” is added to Link option attribute of all seam and area connectors. This is a local option which can be set on individual connector. If link option is set to “two links only,” based on the projection on the links, the connector realization will have only best two links considered.
- Build mesh after imprint
- New option “After Imprint” is added to spot and seam connectors which undergo imprint. This is a global option. With connector realization the mesh around imprint will be built based on Rebuild or Remesh option. By default, “After Imprint” is set to Rebuild.
- Auto trim
- New global option “Auto Trim” is added to seam connectors. Enabling this option will trim the ends of seam connectors based on the average projection length of all the test points. It also trims the connector ends if there are no projections.
- Multiple connectors at proximity
- If seam connector which generates HAZ are at proximity the logic of realization in enhanced such that more connectors gets successfully realized.
- Disassociate FE
- New option “Disassociate FE” is added in connector browser context menu under "Edit ". It breaks the link between FE and connector. The connector turns to modified state.
- New formulations
- For seam quad LTB and seam rigid LTB connector, new formulations T1, T2, Tmin, Tmax and pitch size are added to thickness dependent dimensioning schema.
- Editable hexa thickness option
- Hexa thickness option is made editable for adhesive seam connector in LS-DYNA, PAM-CRASH and Radioss profiles.
Resolved Issues
- Fixed an issue related to distorted mesh with overlapping elements while realizing seam connectors.
- Crash issue while converting spotline connector to seam line connector.
- Fixed an issue related to connector .xml reader while reading link rule “automatic.”
Conversion between Solver Formats
Abaqus to OptiStruct
- Enhancements
- Convert Abaqus C3Dxx I element to OptiStruct PSOLID ISOP = Full.
- Resolved Issues
- INREL, -1 conversion applied on set to SUPPORT1 fixed.
Abaqus to Radioss
- Enhancements
- *HYPERELASTIC Neo Hookean material converted into LAW42
LS-DYNA to Radioss
- Enhancements
- *MAT_JOHNSON_COOK / MAT_015 converted to /MAT/LAW02 with failure model
General
Enhancements
- Undo/Redo support for all morphing panels and commands
- Morphing is now fully compatible with the global undo/redo history. All morphing actions now support undo/redo, and using any of the morphing panels will no longer clear preexisting undo/redo history.
Resolved Issues
- Application crashes when you click update in the set panel without selecting a set.
- Improvements are made in reading binary STL.
- Selected HyperMesh model files fail to load in to HyperWorks 14.0 and 2019 releases.
- Application crash associated with turning off the display entities from the browser configuration dialog.
Geometry
New Features
- Midline
- New HyperWorks Midline workflow added for generating midlines for solid tube geometries as well as creating lines by interpolating between existing lines. Generating midlines for solid tube geometries is useful in creating seam connectors, or for simplifying 3D geometries to 1D.
Enhancements
- Boolean
- “Use Parasolid” option has been added to allow users to use Parasolid geometric kernel for doing Boolean operations like combine, subtract and intersect.
- Split
- Split lines by line option added for split by line method.
- Surface – Cross extend
- Added “Choose target” option item on the guidebar (previously located under options menu) for ease of use.
- Miscellaneous
- Fixed robustness issues related to surface offset, imprint and defeature tools.
Meshing
New Features
- 2D Mesh Support for Element Remeshing
- A new interactive Elements based remesh workflow support has been added for General 2D Mesh, CFD 2D Mesh and Panel Mesh context in HyperWorks.
- Coarsen Elements
Figure 3.
- 1D Coarsen
- A new dedicated 1D coarsen context workflow added to coarsen 1D elements to the user given element size.
- 2D Coarsen
- The improved 2D Coarsen tool.
Enhancements
- BatchMesher
- Improved consistency in identifying beads and improvements done to preserve bead midline option to preserve existing geometry midlines or create bead midline as per user defined parameters.
- Edit Elements
- Graphical previews and pre-calculations have been added relevant
operations.Figure 4.
- Midmesh (HyperWorks only)
- Added option on where to place midmesh at varying thickness sections
(steps).Figure 6.
- Rebuild
- Additional option provided to define explicit flow guides used to guide the mesh direction. This enables multiple mesh pattern based on different flow guides provided.
- Miscellaneous
- Mesh density values can be changed by clicking on density display number independent of model orientation.
Resolved Issues
- Resolved topology connectivity related issues for 2D remeshing.
- Addressed 2D mesh performance and robustness related issues.
- Fixed hole-washer move-modify related segmentation fault.
- Addressed 1D coarsening element config change issue.
- The "Element Quality" visualization mode now properly shows the compound QI and failed elements count based only on the displayed elements.
- Resolved a crash with the Box Trim tool when there is a mixture of first and second order elements.
Model Build
New Features
- Part Matching
- Allows you to create part sets CAD/FE data based on comparison criteria.
Enhancements
- Instance Sync
- A new context menu lets you sync the modified contents of the instances without need of saving modified instance first.
- Upload to PDM
- Upload to PDM functionality in BOM Export GUI now supports Windchill Servers.
Known Issues
- When Legacy HyperMesh representations are imported, you might see Properties grouped as Ungrouped for some Solvers.
Model Verification
New Features
- Highlights
- Comparison function is enhanced with auto comparison, AI comparison and plastic parts comparison.
- Auto Comparison
- “Auto” parameter is added under config/compareunifed to compare parts that are moved in 3d axis (translation, rotation, symmetry) at once. For CAD vs FE and FE vs FE the matched percentage will be displayed without coloring the unmatched elements. By default, this parameter is turned OFF. For CAD vs CAD unmatched entities will be displayed in report and transformation matrix will be exported to YYYYMMDD_HHMMSS_transformationmatrix.txt file under report path.
- AI Approach
- “AI-approach” parameter is added under config/compareunifed to combine AI based logic for the comparison. AI and Shape based comparison will be executed simultaneously and best results will be displayed in the report. Results will be marked as (AI) without displaying unmatched entities in the reports. By default, this parameter is turned OFF.
- Unmatched Ribs
- “Show unmatched ribs” parameter is added to capture missing mesh at the rib area. By default, this parameter is turned OFF.
Enhancements
- Best Match Option
- For CAD vs multiple FE variant comparison, results are grouped under Part Set browser in hierarch structure. Each Set will have pair of CAD and Matched FE.
- Q-Comparison
- Supports HyperMesh format for CAD vs CAD comparison.
- Threshold Value for Comparison
- Space separated multiple threshold values are added by default 30-90% is set. Between last two values BatchMesh will be executed if “mesh-unmatched” parameter is ON.
- Performance on AP242 Format
- Reading and executing intersection on AP242 format has been improved to support large models.
- PartNumber Column for Variant Model
- PartNumber column for variant result is added in Comparison Excel report.
Known Issues
- AI based comparison result will not show unmatched entities in red/blue color.
Resolved Issues
- For the all verification checks auto deleting empty Part that does not have either CAD/Mesh representations.
- PLMXML is supported directly in comparison input selection using XML option.
- Unmatched elements in Comparison report are not shown for few cases is improved.
- Auto rename is executed if component name includes 2byte character.
- Auto rename will be executed if special character like “#” ”@” “+” exist in either component name or material name to avoid XML related issues.
- Zero value is not be accepted for Comparison tolerance.
Stress Tools
New Features
- Beam Config
- New Design Point Config Beam is available with 3 types: Beam, Beam
Member, and Beam Shell. The latter supports Freebody section as a design
point which enables you to perform beam certification methods on shell
elements. Two methods ship with the installation:
- Beam Compressive Crippling
- if sx < 0, MS = sx/Fcc -1; with Fcc= Fcy*(1- Kcrippling*(L’/ r)/p*sqrt(E/Fcy))
- Beam Axial Stress
- if sx > 0, MS = sx/Ftu -1; if sx < 0, MS = sx/Fcy -1
- Chain Methods
- A method can take its arguments as a result from a previous method. This enables you to chain methods one after the other and include some sorting (either spatial aggregation or load case enveloping). JointLoad method for Rivet is not yet a valid method for chaining.
Enhancements
- Dockable Certification Browser
- Certification browser and is now a (un)dockable browser of HyperWorks.
- Contouring Method
- Enhance Contouring UI to support sorting options. Depending on method output and Design Point config, values can be per load case, per layer, or on element vs. on design point.
- Consolidated Table
- Whenever multiple methods are assigned to a Design Point Set, a consolidated table is added which enables you to find the most critical method per location. Method registration needs to tag one output as “Marginofsafety” to be considered a comparison key and be registered in the consolidated table. Contour invoked from Design Point Set level will select the consolidated table. Sort key will be used to compare method MS.
- API to run method on mark of element
- *rundesignmethod API can now run a method directly on a mark of element without Design Points.
CAD and Solver Interfaces
CAD Interface
Enhancements
- Updated version support
- 3DExperience R2020X
- AVEVA Marine E3D 3.1
- CATIA V5-6 R2020
- Inventor 2020
- NX 1899 (third-party reader, native reader support was previously available)
- SolidWorks 2020
- Timeout
- A new timeout feature has been added to the JT and NX native readers.
When enabled, the reader is checked periodically to see if it has
crashed or still alive. If the reader has crashed or is still alive and
running longer than the timeout value, it will be killed. This is
exposed as an option in the relevant .ini files as
well as in the Import GUI as "Timeout". This addresses problems of hangs
and crashes in the reader itself. It does not cover after the reader is
finished and the data is passed to HM, which is not subject to the
timeout.
This is beneficial for loading representations, as a crash/hang in the reader when importing a single leaf of a BOM tree will not prevent the rest of the files from loading. Only the leaves with problems will be skipped.
Please note that for single files, or monolithic files, nothing will be imported if there is a crash/hang in the executable, as this is a per-file operation.
Resolved Issues
- Miscellaneous robustness and performance improvements.
- NX naming scheme is followed when splitting components "by body" with NX native reader.
Abaqus Interface
New Features
- Auto Contact for Abaqus
- A new way of detecting contact surfaces for Auto contact by extending the surfaces based on feature angle is introduced.
- Cohesive Element Modeling
- A new cohesive element modeling is added to the special elements tool in Abaqus.
Enhancements
- Updated Keywords
- *RIGID BODY – The reference node is updated with an option to reference a node set.
Resolved Issues
- An issue with evaluating PARAMETER keyword especially if it spreads across multiple includes is resolved.
- A *COUPLING node with surface type as node will be lost and this issue is fixed.
- In a nested include input file the sets defined are moving out of include file. This issue is resolved and ensured that sets remain in the defined include.
- An issue on losing the property definition as well as property getting mixed between direct and indirect definition is resolved.
- Set of sets lost upon import and export is resolved.
- A performance hit on Auto contact detection is improved.
- An include file containing datalines under *FILM was not exporting, and the issue is resolved in this version.
- A crash issue on card editing *MPC constraint is resolved.
ADVC Interface
Highlights
- Allows HyperMesh to perform model creation and setup for ADVC solver
- The following functions are available in the ADVC user-profile:
- Assembly related
- Geometry related
- Mesh related
- Model Browser
- Entity Editor
- EE customization
- Tool tips
- Create cards
- Menu customization
- Quick search
- HWx interface
- Ribbon customization
- Supported version 2019 R1.2
Solver Cards
- New Cards (Import, Export, Editing)
- Element Cards
Element Type Solver Card 2D Element $ShellLinearTriangle $ShellLinearQuadrangle $ShellQuadraticTriangle $ShellQuadraticQuadrangle $MembraneLinearTriangle $MembraneLinearQuadrangle $MembraneQuadraticTriangle $MembraneQuadraticQuadrangle 3D Element $3DLinearTetrahedron $3DQuadraticTetrahedron $3DLinearPyramid $3DLinearPentahedron $3DLinearHexahedron $3DIMLinearHexahedron $3DRILinearHexahedron $3DQuadraticPyramid 3DQuadraticPentahedron 3DQuadraticHexahedron 3D Gasket Element $3DGasket6 $3DUniaxialGasket6 $3DGasket8 $3DUniaxialGasket8 - Material Cards
Material Type Material Card Isotropic $YoungModulus $YoungModulusInTable $PoissonRatio $PoissonRatioInTable $Density $DensityInTable $ThermalConducitivity $ThermalConducitivityInTable $SpecificHeat $SpecificHeatInTable $ThermalExpansionCoefficient $ThermalExpansionCoefficientInTable $Density $DensityInTable $OrthotropicYoungModulus $OrthotropicYoungModulusInTable $OrthotropicPoissonRatio $OrthotropicPoissonRatioInTable $OrthotropicShearingModulus $OrthotropicShearingModulusInTable $OrthotropicThermalConducitivity $OrthotropicThermalConducitivityInTable $OrthotropicThermalExpansionCoefficient $OrthotropicThermalExpansionCoefficientInTable $SpecificHeat Anisotropic $Density $DensityInTable $OrthotropicYoungModulus $OrthotropicYoungModulusInTable $OrthotropicPoissonRatio $OrthotropicPoissonRatioInTable $OrthotropicShearingModulus $OrthotropicShearingModulusInTable $OrthotropicThermalConducitivity $OrthotropicThermalConducitivityInTable $OrthotropicThermalExpansionCoefficient $OrthotropicThermalExpansionCoefficientInTable $SpecificHeat $SpecificHeatInTable $AnisotropicElasticity Gasket $Density $YoungModulus $PoissonRatio $ThermalExpansionCoefficient $ThermalConducitivity $SpecificHeat $LoadingPath $UnLoadingPath $YieldPressure $TensileModulus $TransverseShearingModulus $LongitudinalShearingModulus $GasketInitialGap $GasketThickness ElasticPlastic / Elastic Attributes $YoungModulus $YoungModulusInTable $PoissonRatio $PoissonRatioInTable $Density $DensityInTable ThermalExpansionCoefficient $ThermalExpansionCoefficientInTable $SpecificHeat $SpecificHeatInTable $ThermalConductivity $ThermalConductivityInTable von Mises with Isotropic Hardening $YieldStress $YieldStressInTable ElasticPlastic / von Mises with Isotropic Hardening $MisesIsotropicHardeningCurve ElasticPlastic / von Mises with Kinematic Hardening $MisesKinematicHardeningCurve ElasticPlastic / von Mises with Combined Hardening $MisesIsotropicHardeningCurve $MisesKinematicHardeningParameter - Property Cards
- $ShellThickness
- Sets Cards
- $ElementSet
- Control Cards
- $CreatorInfo
- Friction and Contact Cards
- $Friction
- LoadSteps and OutputBlocks
- $Process
- Unsupported Cards
- For all unsupported cards, Import and Export is supported. Integrity of these cards will be maintained inside HyperMesh.
- Known Limitations for Include File Path
- Include paths in the Include Browser will be displayed with respect to the master file directory. Integrity of the include paths will be maintained on import and export.
- Note: If you plan to add a new include file, you have to make sure that the include path is defined with respect to the master file directory.
EXODUS Interface
Enhancements
- Sectional properties
- Under the EXODUS user profile, you can define sectional properties like thickness, beam cross sectional area, moment of inertia etc. into the HyperMesh property object and it will be referred to in the component. The equivalent of solver BLOCK entity is mapped to HyperMesh property entity.
- Seamless data mapping across solvers
- The Comp-Propt-Mat relationship in Nastran and OptiStruct enables seamless data mapping across solvers.
LS-DYNA Interface
New Features
- New Keywords
- New keywords for LS-DYNA solver have been added in the following keywords groups: *CONTROL_REQUIRE_REVISION, *CONTACT_{OPTION}, *INTERFACE_LINKING_NODE_{OPTION}, *MAT_{OPTION}.
- Seatbelt Auto Extraction
- Added a new feature to Auto Generate seatbelts into the Seatbelt Browser. In case the HyperMesh seatbelt metadata are not present in the solver deck, this feature enables to quickly recover of the seatbelt system without having to recreate it completely and manually. For more details on the feature, refer to section in the online help.
- New Entity Type for Mass
- Keywords *ELEMENT_MASS, *ELEMENT_MASS_NODE_SET, *ELEMENT_MASS_PART, *ELEMENT_MASS_PART_SET, *ELEMENT_INERTIA, *ELEMENT_INERTIA_OFFET were originally supported as elements, but are now mapped to an independent entity, with own IDs and icon. A specific graphic review for *ELEMENT_MASS is also available to review the nodal mass distribution. The entity state of the Solvermass entity is now considered for the mass calculation. When it is OFF, the lumped mass added by the corresponding *ELEMENT_MASS keyword is ignored. The legacy mass creation from panel is no longer available.
- Keyword Export Order
- Only for LS-DYNA R11.1 solver profile, the keywords order upon export is changed to a more meaningful order. Furthermore, material keywords are now exported by ascending IDs and not more by material type. This change is valid for all the LS-DYNA user profiles.
- New Composite Browser
- This new browser regroups all the composites features and related entities in a same location for a more efficient management of the composite models.
Enhancements
- Updated Keywords
- Existing keywords from keywords groups *CONTROL_OUTPUT, *CONTACT_{OPTION}, *INCLUDE_TRANSFORM, *KEYWORD, *MAT_{OPTION}, *RIGIDWALL_GEOMETRIC_CYLINDER, *SECTION_BEAM, *SECTION_SOLID_{OPTION}, have been updated regarding latest LS-DYNA solver version.
- Element Time Step and Added Mass
- Improvements have been made to the time step and numerical added mass calculation for all element types, according to the solver specific behaviors.
- Model Checker
- Some improvements have been made in the LS-DYNA Model Checker in terms of performances and checks coverage. Added check for *ELEMENT_MASS_PART, *ELEMENT_SEATBELT_ACCELEROMETER and *ELEMENT_SEATBELT_SLIPRING.
- Mass Calculation
- Performance and accuracy improvements are made while calculating mass through the Mass Details tool.
Resolved Issues
- Now ID suffix is optional for *AIRBAG_PARTICLE, card edit or entity editor have additional check box IdOpt.
- Curve selection fields in material are enabled to select *DEFINE_TABLE_2D, *DEFINE_TABLE_2D & *DEFINE_TABLE_3D.
- Added improvements to *KEYWORD with memory option.
- Field Damage evolution parameter Q1 of *MAT_ADD_EROSION is improved to handle both curve and float values which also resolves export issue.
- Additional flags 0.0 and 1.0 added to Temperature transformation factor FCTTEM along with existing four character flags for *INCLUDE_TRANSFORM.
- Import and export issues resolved for *ELEMENT_MASS_PART_SET when associated with *INCLUDE_TRANSFORM.
- Fixed issue of creating invalid component while reading ANSA comments with import option active.
- Avoid crash while reading invalid keyword options for *SET_SEGMENT_GENERAL and provided import warning message.
- Performance improvements while handling *SET_SEGMENT_GENERAL.
- Import warning message provided whenever duplicate components exist in the input deck.
- User comments are retained in *PARAMTER keyword entity editor and maintained location upon export.
- Advanced deletion of component will account Solvermass entity association.
Marc Interface
New Features
- New Keywords
- ALLPOINTS
- AUTOLOAD
- MARLOW MATERIAL
Resolved Issues
- Assignment of elements to components with same property as per version13.
- Import warning provided for decks imported without version card in the deck, and all the decks are imported with version card 13.0 as default.
OptiStruct Interface
New Features
- OptiStruct Solver Feature Enhancements
- This release includes critical enhancements from OptiStruct solver features released in 2020, 2020.1.
- Auto Contact for OptiStruct
- A new way of detecting contact surfaces for Auto contact by extending the surfaces based on feature angle has been introduced. Additional option to update the search distance field in contact/tie card from tolerance value has also been added.
- Plane Strain
- New element types: CQPSTN and CTPSTN (both 1st and 2nd order)
- Temperature Dependent Material Enhancements
- Convection coefficient on MAT4 can be temperature-dependent, Table input is required and referenced by the corresponding MATT4. Specific heat on MAT4 can be temperature-dependent, Table input is required and referenced by the corresponding MATT4.
- Model Checker OptiStruct
- The following error checks added in model checker for OptiStruct:
- Elements missing property definition.
- Fatigue Analysis
- Options for Pseudo Damage method definition in FATPARM card.
- Optimization
- DSYSID enhanced to allow TABLED input
General Enhancements
- Corner option extended for discretization type N2S when track option is set to CONSLI in contact card
- NLOUT card is enhanced to define desired time points output for Nonlinear subcase
- Restart write (RESTARTW) defined at subcase level
- Mass/Volume distribution in NSML1
- New joint types ROTATION, CARTROTA, INPLORIE added in JOINTG elements
- Contact card is enhanced to support cohesive zone modeling using contact through COHE continuation line and the corresponding MCOHEDID field can reference the MCOHED card
- User defined path to write restart file in RESTARTW card
- Bergstorm_boyce model type added in MATVE material card
- Label field added to TABLEG card
- New options added to SYSSETTING card, SYSSETTING(EMPTYSET=ERROR/WARN) and SYSSETTING(IR4MECH = YES)
- Stress/Strain Output card added to request corner and gauss results together
- STATIS/OSTATIS output option for transient analysis
- Subcase specific parameters: W3, W4, WR4, WR4 and WRH
- Edit/Update DDVAL from entity editor
- Output options added for energy-related quantities in Acoustics
Resolved Issues
- MODEL I/O card was imported correctly
- Export issue with grid/elem having ID more than 9 characters in free format
- Unable to create SURF card from solid face selection
- Terminology change for MCOHED card
- Shape variable ID changes after performing remesh in OSSMOOTH
PAM-CRASH 2G Interface
New Features
- New Keywords
- New keywords MATER Type 306, OPTLIS, PLY (Type 10, 15), PLY Failure Model (Type 10, 11) have been added.
Enhancements
- Updated Keywords
- BAGIN, CCTRL, CKCTRL, CNTAC (Type 33, 34, 36, 37, 43, 44, 46, 54, 154), ECTRL, EIGEN, EXPORT, FPCTRL, HEAT, IMPORT, LAYER, LCTRL, NLAVE, MATER Type 225, OCTRL, OTMCO, PICEXP, PICIMP, PLINK, PRCTRL, SENSOR (Type 4, 7), RUPMO, SHELLCHECK, SOLIDCHECK.
Resolved Issues
- Avoid moving user comments of keywords to Imported Model Documentation block.
- Empty check on Output Block when entities referred through set is corrected.
- PLINK elements are no more listed as free 1D elements.
Radioss Interface
New Features
- New Keywords
- Following new keywords are added in Radioss 2020 user profile: /ALE/ON, /ALE/OFF, /FAIL/COCKCROFT, /FRIC_ORIENT, /SENSOR/ENERGY.
Enhancements
- Updated Keywords
- Following keywords have been updated to the latest Radioss 2020 version: /ANIM/BRICK, /FAIL/ENERGY, /FAIL/HASHIN, /FAIL/VISUAL, /INTER/TYPE11, /INTER/TYPE19, /INTER/TYPE21, /MAT/LAW63, /MAT/LAW77, /MAT/LAW81, /MAT/LAW92, /MAT/LAW95, /MAT/LAW100, /TH/QUAD.
- Model Checker
- Enhancement made in the detection of Incompatible Kinematic Conditions on nodes.
- To be consistent with the export of all other keywords, the material keywords are now exported by ascending IDs and not more by material type. This change is valid for all the Radioss user profiles.
- Elemental Time Step Calculation
Resolved Issues
- Error fixed on import of H3D file in the dummy pre-simulation process, for a specific dummy model.
- Error fixed when penetration check is run twice with the option “consider edge penetrations” is activated.
- Fixed segmentation error when selecting assembly in set and assembly view is open.
