Transfer Load Mapping Examples
This method is useful when transferring data from existing solver decks (.bdf, .fem, .inp, and so forth) to new meshed models. Old mesh shape functions are used with this method.
The x,y,z values in .csv files can be used without old mesh data. Discrete mapping (close point approach) will be used instead, which is less accurate than continuous shape function mapping. The matrix utility can be used to export x,y,z value data from old solver decks to a .csv file.
