Coarsen: 1D Tool
An overview of the Coarsen: 1D tool.
Use the Coarsen 1D tool to coarsen 1D elements and components.
- Access
- Go to .
Options
- Element size
- The size of the element.
- Maximum deviation factor
- The maximum allowable deviation between an element edge and a geometry edge, as a factor of the average element size.
- Feature angle
- The feature angle for common edge smoothing.
- Delete small features factor
- Remove most features that become detached during the coarsening process, which are underneath the target input size that you specified.
