/MAT/LAW16 (GRAY)
Block Format Keyword This material law is based on Gray EOS and Johnson-Cook yield criteria.
/MAT/LAW16/mat_ID or /MAT/GRAY/mat_ID | |||||||||
mat_title | |||||||||
E | ν | ||||||||
a | b | n | |||||||
P0 | C | S | 0 | αe | |||||
AW | Pmin | E0 | |||||||
c | m | Tmelt | Tmax | ||||||
0m | αm | e | ge | S | |||||
Tm0 | Vj | Vb | |||||||
U | Eoh | Ay |
mat_ID | Material
mat_title | Material
Initial
density (Real) |
Reference density used in
E.O.S (equation of state). Default = = (Real) |
E | Young's
modulus (Real) |
ν | Poisson's
ratio (Real) |
a | Plasticity yield
stress. (Real) |
b | Plasticity hardening
parameter. (Real) |
n | Plasticity hardening
exponent. Default = 1.0001 (Real) |
Failure plastic
strain. Default = 1030 (Real) |
Plasticity maximum
stress. Default = 1030 (Real) |
P0 | Initial
pressure. (Real) |
C | Hugoniot
parameters. (Real) |
S |
(Real) |
0 | Lattice
gamma (Real) |
e |
(Real) |
AW | Atomic
weight (Real) |
Pmin | Pressure cutoff Default = -1030 (Real) |
E0 | Initial energy per unit
volume. (Real) |
c | Strain rate coefficient.
(Real) |
Reference strain rate
(time unit)-1. (Real) |
m | Temperature
exponent. Default = 1.0 (Real) |
Tmelt | Melting
temperature. Default = 1030 (Real) |
Tmax | For T >
Tmax: m =1 is used. Default = 1030 (Real) |
0m | Melting gamma. Default = 0 (Real) |
m |
Default = a (Real) |
e | Electronic
gamma. Default = 2/3 (Real) |
ge | Electronic energy
coefficient. Default = 0.0 (Real) |
S | Entropy of
melting. Default = U x 9.637e-5 (Real) |
Tm0 | Melting temperature
parameter. Default = 1.3 Tmelt (Real) |
Vj | Volume where EOS are
joined. (Real) |
Vb | Excluded volume for vapor
phase. Default = 0.5/r0 (Real) |
U | 1 Mbar cm3 to
be converted in user's unit. Default = 1.0 (Real) |
Eoh | Energy at
V=V0,
T=300K,
P=0. Default = 0.0 (Real) |
Ay | Coefficient of attractive
potential. (Real) |
Join parameter. Default = 1.0 (Real) |
Example (Aluminum)
#RADIOSS STARTER
/MAT/LAW16/1
Aluminium - GRAY EOS (unit g_cm_mus)
# RHO_I RHO_0
2.7 0
# E Nu
0.71 .33
# a b n Eps_max sigmax
0.002 0.00144 0.62 0 0
# P0 C S Gamma_0 a_e
0 0.533 1.338 2.18 1.7
# AW P_min E0
26.98 -5e-3
# c eps_dot_0 m T_melt T_max
1 1E30
# Gamma_0m a_m Gamma_e g_e delta_S
2.18 1.7 0.6667 8.7e-9 9.637E5
# T_m0 V_j V_b
1220 0.47388 0.19025
# U E_0h a_y Theta
1 0 47 1
#ENDDATA
Reference
E. B. Royce, GRAY, a three-phase equation of state, UCRL-51121, Lawrence Livermore Laboratory, 1971
Comment
(1)
