Processing math: 100%
/MAT/LAW78
Block Format Keyword This law is the Yoshida-Uemori model for describing the large-strain cyclic plasticity of metals. The law is based on the framework of two surfaces theory: the yielding surface and the bounding surface.
During the plastic deformation, a yield surface will move within the bounding surface and will never change its size, and the bounding surface can change both in size and location. The plastic-strain dependency of the Young's modulus and the work-hardening stagnation effect are also taken into account. Concerning SPH, it is compatible with solid only, this can be verified with the /SPH/WavesCompression test. The solid version is only isotropic. The shell version is anisotropic based on Hill criterion.
/MAT/LAW78/mat_ID/unit_ID
mat_title
ρi
E ν
Y b C h B0
m Rsat OptR C1 C2
r00 r45 r90
fct_IDE   Einf CE
mat_ID Material identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
mat_title Material title
ρi Initial density
(Real)
[kgm3]
E Young's modulus
(Real)
[Pa]
ν Poisson's ratio
(Real)
Y Yield stress
(Real)
[Pa]
b Center of the bounding surface.
(Real)
[Pa]
C Parameter for kinematic hardening rule of yield surface.
(Real)
h Material parameter for controlling work hardening stagnation.
(Real)
B0 Initial size of the bounding surface.
(Real)
[Pa]
m Parameter for isotropic and kinematic hardening of the bounding surface.
(Real)
Rsat Saturated value of the isotropic hardening stress.
(Real)
[Pa]
OptR Modified isotropic hardening rule flag (available for shells only):
=0 (Default)
Yoshida formulation.
=1
Modified formulation (define C1 and C2).
(Integer)
C1, C2 Constant used in the modified formulation of the isotropic hardening of bounding surface (available for shells only).
(Real)
r00, r45, r90 Material parameters determining anisotropy in Hill's (48) yield criterion (in shell version).
Default = 1.0 (Real)
fct_IDE ID of the function defining the scale factor of Young's modulus evolution versus effective plastic strain. 7
(Integer)
Einf Asymptotic value of Young's modulus.
(Real)
[Pa]
CE Parameter controlling the dependency of Young's modulus on the effective plastic strain.
(Real)
#RADIOSS STARTER
/UNIT/1
unit for mat
                 Mg                  mm                   s
#-  2. MATERIALS:
/MAT/LAW78/1/1
DP600-HDG
#              RHO_I
              7.8E-9
#                  E                  NU
              206000                  .3
#                  Y                   B                   C                   H                  B0
                 420                 112                 200                   0                 555
#                  m                RSAT      OPTR                  C1                  C2
                  12                 190         0                   1                   1
#                 R0                 R45                 R90
                   1                   1                   1
#  fct_IDE                          EINF                  CE
         0                             1              163000
#ENDDATA
/END
  1. For solid elements, von Mises yield criterion is used, so the yield function is expressed as:(1)
    f=32(sα):(sα)Y2
    Whereas for shell elements, Hill's (48) yield criterion is used, which allows modeling anisotropic materials and it is expressed as:(2)
    f=φ(σα)Y2
    Where, ( φ ) is expressed as:(3)
    φ(A)=A2xx2r01+r0AxxAyy+r0(1+r90)r90(1+r0)A2yy+r0+r90r90(1+r0)(2r45+1)A2xy
  2. Yield stress, Poisson ratio and Young's modulus should be strictly positive. The other parameters should be non-negative value.
  3. The schematic illustration of the two-surface model is shown in Figure 1.
    Where, 0 is the original center of the yield surface, the yield surface with its center α and its radii Y, is moving kinematically, within a bounding surface that has a size indicated by B+R and tensor β indicating its center position.
    law78_2-surface_model
    Figure 1. Schematic Drawing of the Two-surface Model
  4. The yield surface is subjected to a kinematic hardening. The kinematic motion is described by α* that has the following evolution:
    ˙α*=C[(aY)(σα)aα*α*]˙ˉεp
    for shell elements
    ˙α*=C[(23)a˙εpaα*α*˙ˉεP]
    for solid elements
    Where,
    • ˙ˉεp is the equivalent plastic strain rate
    • C and a are material parameters. And a=B+RY
    • α=α*+β is the total back stress
  5. The bounding surface is subjected to an isotropic-kinematic hardening. The evolution equation for isotropic hardening is:
    ˙R=m(RsatR)˙ˉεp
    Default (if OptR = 0) Yoshida expression
    R=Rsat[(C1+ˉεp)C2CC21]
    Available for shell elements, if OptR = 1
    The evolution equation for kinematic hardening of bounding surface is:(4)
    ˙β=m(23b˙εpβ˙ˉεp)
  6. The work-hardening stagnation during unloading is described using a J2-type surface gσ with a radius r and a center q:(5)
    gσ(β,q,r)=32(βq):(βq)r2˙q=μ(βq)r=h˙Γ,˙Γ3(βq):˙β2r
    Where, β should be either inside or on the surface gσ .
  7. The evolution of Young's modulus:
    • If fct_IDE > 0, the curve defines a scale factor for Young's modulus evolution with equivalent plastic strain, which means the Young's modulus is scaled by the function f(ˉεp) :
      • E(t)=Ef(ˉεp)
      The initial value of the scale factor should be equal to 1 and it decreases.
    • If fct_IDE = 0, the Young's modulus is calculated as:(6)
      E(t)=E(EEinf)[1exp(CEˉεp)]
      Where,
      E and Einf are respectively the initial and asymptotic value of Young's modulus, ˉεp is the accumulated equivalent plastic strain.
      Note: If fct_IDE = 0 and CE = 0, Young's modulus E is kept constant.
  8. This material law is not available for implicit analysis.
