poILegend GetMin
Gets the minimum result value.
poILegend_handle GetMin
HyperView Tcl Query
This command returns the minimum result value.
None.
Gets the bounding box of the legend.
Gets the category legend label.
Gets the contributing category layer name list for a Max/Min/Extreme layer contour.
Gets the contributing category label list for Category Legend plots.
Gets a handle to a cloned copy of this legend.
Gets the color at the given level index.
Gets the default script file path.
Gets the default legend state.
Gets the discrete coloring mode of the legend.
Gets the legend style.
Gets a valid numeric legend filter list.
Gets the footer text.
Gets the text attribute handle for the footer text.
Gets the header text.
Gets a font handle for the header font.
Gets the height of the legend bounding box.
Gets the maximum result value.
Gets the legend maximum for a given model ID.
Gets the maximum number of levels allowed in the Category Legend for a Max/Min/Extreme layer contour.
Gets the legend minimum for a given model ID.
Gets the maximum and minimum legend visibility state.
Gets the text attribute handle for the legend numbers.
Gets the number of color levels.
Gets the format string used by the legend.
Sets the precision for numbers.
Sets the location of the legend.
Enables/disables the reverse state of the legend.
Sets the state of the Show Category ID option for the Category Legend.
Sets the legend style.
Sets the legend type.
Sets the legend visibility.
Applies the settings for the cloned legend to the original legend.
Removes the override value for the given color level.
HyperView Tcl Query
None.
