mdlIModelClient ForceDrawOfImplicitMarker
Used to draw/display the implicit marker graphic of the selected marker.
mdlIModelClient_Handle ForceDrawOfImplicitMarker force, material_name
MotionView Tcl Modify
This command draws/displays the implicit marker graphic of the selected marker, and returns (0) if successful.
- force
- True or False is returned for this argument.
- material_name
- The name of the material.
hwi OpenStack
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
mcl CreateBlankModel
mcl GetModelHandle m
m InterpretEntity p0 Point p_0 "\"A Pt\"";
m InterpretSet SetPoint p_0 0 0 0;
m InterpretEntity b0 Body b_0 "\"A\"" p_0;
m InterpretEntity j0 BallJoint j_ball "\"Ball\"" b_0 B_Ground p_0;
m GetChildHandle jmim j_ball.i.implicit;
jmim ForceDrawOfImplicitMarker true MODEL.mat_aluminum_alloy;
m Evaluate;
jmim ReleaseHandle;
p0 ReleaseHandle;
b0 ReleaseHandle;
j0 ReleaseHandle;
m ReleaseHandle;
mcl ReleaseHandle;
win1 ReleaseHandle;
pa1 ReleaseHandle;
pro1 ReleaseHandle;
sess1 ReleaseHandle;
hwi CloseStack;
None.
