mdlIModelClient GetWizardLibDir
Gets the directory that contains the files to create the wizard for the specified profile.
mdlIModelClient_Handle GetWizardLibDir arg_Profile
MotionView Tcl Query
This command retrieves the directory according to the argument passed.
- arg_Profile
- Valid arguments are:
- User
- Settings specified for the user profile.
- Pref
- Settings specified in the preference file.
hwi OpenStack
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
set temp [mcl GetWizardLibDir User]
puts "The Directory that Contains the Files to Create the wizard for User Profile Is $temp"
mcl ReleaseHandle;
win1 ReleaseHandle;
pa1 ReleaseHandle;
pro1 ReleaseHandle;
sess1 ReleaseHandle;
hwi CloseStack;
None.
