mdlIModelClient UpdateObjectInBrowser
Updates the entity info (if it is present) in the browser and updates the corresponding views.
mdlIModelClient_Handle UpdateObjectInBrowser recursive
MotionView Tcl Modify
This command updates the entity info (if it is in the browser) and updates the corresponding views. If the recursive argument is set to true, the update will be done on the object and its children recursively.
- recursive
- A boolean input value:
- True
- The children of the entity will also be updated recursively.
- False
- Only the entity will be updated.
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
mcl GetRootObjectHandle mo
mcl UpdateObjectInBrowser mo true
mo ReleaseHandle
mcl ReleaseHandle;
win1 ReleaseHandle;
pa1 ReleaseHandle;
pro1 ReleaseHandle;
sess1 ReleaseHandle;
Returns 0 if successful, otherwise an error code.
