poIComponent GetDisplayMode
Gets the component display option setting.
Important: Please note that this command has been deprecated and therefore is not recommended for use. See the poIPart Class for an alternative command that can be used.
poIComponent_handle GetDisplayMode name
HyperView Tcl Query
This command returns the component display option setting.
name
The display option name.
Returns true if the display option is on, or false if the display option is off.
