poIComponent SetTracingMode
Sets the component’s tracing mode.
Important: Please note that this command has been deprecated and therefore is not recommended for use. See the poIPart Class for an alternative command that can be used.
poIComponent_handle SetTracingMode mode
HyperView Tcl Modify
This command sets the component’s tracing mode.
mode
The tracing mode: off, first, all, last (number of steps).
Error
Returns 0 if successful, otherwise an error code.
