poIComponent SetDisplayMode
Sets the component's display mode.
poIComponent_handle SetDisplayMode name state
HyperView Tcl Modify
This command sets the component’s display mode.
- name
- The display option name.
- id
- Display the component Id.
- boundingbox
- Display the component's bounding box.
- infit
- If true, include the component in fit operations. Otherwise exclude it.
- state
- The display option value: true for on, or false for off.
Error
Returns 0 if successful, otherwise an error code.
