poIIsoValueCtrl SetDisplayMode
Sets the current display mode.
poIIsoValueCtrl_handle SetDisplayMode set
HyperView Tcl Modify
This command the current display mode.
set
Set to "equal", "below", or "above". The iso value geometry is drawn based on this option.
Returns 0 if successful, otherwise an error code.
