poIIsoValueCtrl SetIgnoredFlippedNormal
Sets the state of the "Ignore Flipped Normal" option for the feature angle average.
iso_handle SetIgnoreFlippedNormal state
HyperView Tcl Modify
This command sets the state of the "Ignore Flipped Normal" option for the feature angle average.
- state
- A Boolean value to set the "Ignore Flipped Normal" state (True or False).
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetIsoValueCtrlHandle iso_handle
# set the Ignore Flipped Normal state to false
iso_handle SetFeatureAngleAverageEnableState true
iso_handle SetFeatureAngleAverage 45
iso_handle SetIgnoreFlippedNormal false
hwi CloseStack
Returns an error if the value state cannot be applied.
