poIModel SetDisplayMode
Sets the component display option setting. If this component is an assembly, all the child parts will be set to this state.
poIModel_handle SetDisplayMode name state
HyperView Tcl Modify
This command sets the component display option setting. If this component is an assembly, all the child parts will be set to this state.
name
Displays option name: "id", "boundingbox", or "infit".
state
Displays option value: "true" if the given display option is on, or "false" if the given display option is off.
Returns 0 if successful, otherwise an error code.
