poIModel SetPolygonMode
Sets the component's polygon mode. If this is an assembly, ALL child parts are set to the specified polygon mode.
poIModel_handle SetPolygonMode mode
HyperView Tcl Modify
This command sets the component's polygon mode. If this is an assembly, ALL child parts are set to the specified polygon mode.
mode
The polygon mode: transparent, opaque, or wireframe.
Returns 0 if successful, otherwise an error code.
