Smooth Elements
Use the Edit Elements: Smooth tool to optimize the quality of selected elements.
A node of a shell element is free, and therefore can be moved, if none of the following statements are true:
  • It is used by an element that was not selected.
  • It is selected as an anchor node.
  • It is attached to an edge, vertex, or meshing fixed point of a surface.
  • It is used by a 1D element (whether or not that element is selected).
  • It is not attached to a surface, but is on a feature line of the mesh of the selected plate or shell elements.
  1. From the Elements ribbon, click the Edit Elements > Smooth tool.
    Elements are colored according to how well they adhere to the pre-set quality requirements defined in the criteria file.
  2. Optional: On the guide bar, click to to define the options used to edit elements.
  3. Select the element(s) to smooth.
  4. Optional: Select anchor nodes in the following ways:
    • Hold Ctrl while left-clicking.
    • Activate the Anchors selector on the guide bar then make your selection.
  5. In the microdialog, select a smoothing method then click Smooth.
    Auto
    Calculates the lengths of all of the elements’ edges to finds the extreme values. If the ratio of smallest to largest is below a certain threshold, than the Fix Shape method will be used. If the ratio of smallest to largest is above a certain threshold, than the Fix Size method will be used.
    Fix Size
    Moderates variations in element edge size through the mesh using a modified Laplacian over-relaxation that correctly handles a mixture of quad and tria elements.
    Fix Shape
    Moderates variations in element aspect ratio through the mesh using a modified isoparametric-centroidal over-relaxation that correctly handles a mixtures of quad and tria elements.
    Q.I. Warm, Q.I. Good, Q.I. Ideal
    Sets the quality of the optimization target to the corresponding value on the quality index.
Edit Elements: Smooth Tool
An overview of the Edit Elements: Smooth tool.
Figure 3.
Access
Go to Elements > Edit Elements > Smooth.
Option
Allow to move fixed and shared nodes
Allow moving fixed and shared nodes for element operations.
