Summary of ALE Keywords
Usual Radioss keywords will act on material at related grid points. All the parameters starting with /ALE will directly act on the grid points.
It is also possible to define Lagrangian nodes within an ALE part by using /ALE/BCS or merging a Lagrangian element.
This is often used in FSI modeling to window a moving free structure with an ALE grid. For example, in ditching, a limited ALE domain can be linked to free interfaced structure. The advantage is that the water and air inlets are constant, since it is initial state with no material velocity.
- /INTER/TYPE1 (ALE nodes on a Lagrangian surface)
- /INTER/TYPE9 (interfacing a Lagrangian surface with a given ALE free surface)
- /INTER/TYPE12 (enables the transmission of flow between 2 ALE surfaces (master and slave side))
- /INTER/TYPE18 (coupling with Lagrange structure)
- /INTER/TYPE22 (cut cell method, BETA software release)
- Multi-material laws
- /MAT/LAW37 (BIPHAS) (bi-material liquid gas)
- Multi-Phase material law
- /MAT/LAW26 (SESAM) (SESAME-Johnson-Cook material)
- Boundary material law
- /MAT/LAW11 (BOUND) (Inlet/Outlet material)
- Thermal law
- /MAT/LAW18 (THERM) (Thermal material)
- /MAT/LAW2 (PLAS_JOHNS)
- /MAT/LAW3 (HYDPLA)
- /MAT/LAW4 (HYD_JCOOK)
- /MAT/LAW5 (JWL)
- /MAT/LAW6 (HYDRO or HYD_VISC)
- /MAT/LAW10 (DPRAG1)
- /MAT/LAW16 (GRAY)
- /MAT/LAW21 (DPRAG)
- /MAT/LAW41 (LEE_TARVER)
- /MAT/LAW46 (LES_FLUID)
- /MAT/LAW49 (STEINB)
- /MAT/LAW51 (MULTIMAT)
- /MAT/LAW75 (POROUS)
- /MAT/LAW80
- /EBCS
- /MAT/LAW11 (BOUND) (general case, except if using LAW37 or LAW51)
- /MAT/LAW37 (BIPHAS) (see elementary formulation when using multi-material LAW37)
- /MAT/LAW51 (MULTIMAT) (see elementary formulations when using multi-material LAW51)
- /INIVEL (scattered scheme)
- /ALE/SOLVER/FINT Iform=2
It provides more accurate results for non parallelepipedic shapes. See default formulation for under-integrated formulation in Reduced Integration Method in the Theory Manual.
- High Explosive material laws
- /MAT/LAW5 (JWL)
- High Explosive Ignitions
- /DFS/DETLINE (detonation line)
- /DFS/LASER (LASER beam)
- /MAT/LAW26 (SESAM) (SESAME-Johnson-Cook material - only compatible material)
