ADVC Interface 2020.1 Release Notes
Altair HyperMesh
Highlights
- Allows HyperMesh to perform model creation and setup for ADVC solver
- The following functions are available in the ADVC user-profile:
- Assembly related
- Geometry related
- Mesh related
- Model Browser
- Entity Editor
- EE customization
- Tool tips
- Create cards
- Menu customization
- Quick search
- HWx interface
- Ribbon customization
- Supported version 2019 R1.2
Solver Cards
- New Cards (Import, Export, Editing)
- Element Cards
Element Type Solver Card 2D Element $ShellLinearTriangle $ShellLinearQuadrangle $ShellQuadraticTriangle $ShellQuadraticQuadrangle $MembraneLinearTriangle $MembraneLinearQuadrangle $MembraneQuadraticTriangle $MembraneQuadraticQuadrangle 3D Element $3DLinearTetrahedron $3DQuadraticTetrahedron $3DLinearPyramid $3DLinearPentahedron $3DLinearHexahedron $3DIMLinearHexahedron $3DRILinearHexahedron $3DQuadraticPyramid 3DQuadraticPentahedron 3DQuadraticHexahedron 3D Gasket Element $3DGasket6 $3DUniaxialGasket6 $3DGasket8 $3DUniaxialGasket8 - Material Cards
Material Type Material Card Isotropic $YoungModulus $YoungModulusInTable $PoissonRatio $PoissonRatioInTable $Density $DensityInTable $ThermalConducitivity $ThermalConducitivityInTable $SpecificHeat $SpecificHeatInTable $ThermalExpansionCoefficient $ThermalExpansionCoefficientInTable $Density $DensityInTable $OrthotropicYoungModulus $OrthotropicYoungModulusInTable $OrthotropicPoissonRatio $OrthotropicPoissonRatioInTable $OrthotropicShearingModulus $OrthotropicShearingModulusInTable $OrthotropicThermalConducitivity $OrthotropicThermalConducitivityInTable $OrthotropicThermalExpansionCoefficient $OrthotropicThermalExpansionCoefficientInTable $SpecificHeat Anisotropic $Density $DensityInTable $OrthotropicYoungModulus $OrthotropicYoungModulusInTable $OrthotropicPoissonRatio $OrthotropicPoissonRatioInTable $OrthotropicShearingModulus $OrthotropicShearingModulusInTable $OrthotropicThermalConducitivity $OrthotropicThermalConducitivityInTable $OrthotropicThermalExpansionCoefficient $OrthotropicThermalExpansionCoefficientInTable $SpecificHeat $SpecificHeatInTable $AnisotropicElasticity Gasket $Density $YoungModulus $PoissonRatio $ThermalExpansionCoefficient $ThermalConducitivity $SpecificHeat $LoadingPath $UnLoadingPath $YieldPressure $TensileModulus $TransverseShearingModulus $LongitudinalShearingModulus $GasketInitialGap $GasketThickness ElasticPlastic / Elastic Attributes $YoungModulus $YoungModulusInTable $PoissonRatio $PoissonRatioInTable $Density $DensityInTable ThermalExpansionCoefficient $ThermalExpansionCoefficientInTable $SpecificHeat $SpecificHeatInTable $ThermalConductivity $ThermalConductivityInTable von Mises with Isotropic Hardening $YieldStress $YieldStressInTable ElasticPlastic / von Mises with Isotropic Hardening $MisesIsotropicHardeningCurve ElasticPlastic / von Mises with Kinematic Hardening $MisesKinematicHardeningCurve ElasticPlastic / von Mises with Combined Hardening $MisesIsotropicHardeningCurve $MisesKinematicHardeningParameter - Property Cards
- $ShellThickness
- Sets Cards
- $ElementSet
- Control Cards
- $CreatorInfo
- Friction and Contact Cards
- $Friction
- LoadSteps and OutputBlocks
- $Process
- Unsupported Cards
- For all unsupported cards, Import and Export is supported. Integrity of these cards will be maintained inside HyperMesh.
- Known Limitations for Include File Path
- Include paths in the Include Browser will be displayed with respect to the master file directory. Integrity of the include paths will be maintained on import and export.
- Note: If you plan to add a new include file, you have to make sure that the include path is defined with respect to the master file directory.
Altair HyperView
- Enhancements
- Reading of ADVC into HyperView from multiple sub-folders is now supported.
- Resolved Issues
- Incorrect calculation of vonMises strain from strain tensor output.
