EXODUS Interface 2020.1 Release Notes
Altair HyperMesh
Enhancements
Sectional properties
Under the EXODUS user profile, you can define sectional properties like thickness, beam cross sectional area, moment of inertia etc. into the HyperMesh property object and it will be referred to in the component. The equivalent of solver BLOCK entity is mapped to HyperMesh property entity.
Seamless data mapping across solvers
The Comp-Propt-Mat relationship in Nastran and OptiStruct enables seamless data mapping across solvers.
