*addnewmodel
Used by multiple models to add a new secondary model.
*addnewmodel name
HyperMesh Tcl Modify Command
Used by multiple models to add a new secondary model. A new file can be loaded in this newly created secondary database.
name
The unique name of the new model to add.
Examples
To add a new secondary model named model-2:
*addnewmodel model-2
   # Handle error
Version History
2019
