*removecrbrelation
Removes a master-slave relationship for LS-DYNA *CONSTRAINED_RIGID_BODIES keyword.
*removecrbrelation mark_id
HyperMesh Tcl Modify Command
If a master component is removed, then the constrainedrigidbodies entity is deleted. If all slave components are removed, the constrainedrigidbodies entity is deleted.
mark_id
The ID of the mark containing the components.
To remove slave rigid component 200:
*createmark comps 1 200
*removecrbrelation 1
   # Handle error
Version History
14.0.120
