poIPost SetMeasureAngleFormat
Sets the angle format used by all angle measures in this window.
poIPost_handle SetMeasureAngleFormat format
HyperView Tcl Modify
This command sets the angle format used by all angle measures in this window.
format
The angle format, either degrees or radians.
Returns 0 if successful, otherwise an error code.
