poIContourCtrl GetThresholdMin
Gets the minimum threshold value of the contour.
poIContourCtrl_handle GetThresholdMin
HyperView Tcl Query
This command retrieves the minimum threshold value of the contour.
To get the minimum threshold value of the current contour plot:
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myModelName GetResultCtrlHandle myResultName
myResultName GetContourCtrlHandle myContourName
myContourName GetThresholdMin
Error
Returns the current minimum threshold value, or an error code (HW_InvalidHandle) if the handle used to invoke the method is no longer valid.
