poIContourCtrl SetDimensionEnabled
Sets the dimension state; enabled or disabled.
poIContourCtrl_handle SetDimensionEnabled dim_label state
HyperView Tcl Modify
This command sets the dimension state; enabled or disabled.
dim_label
The dimension state. Options include "line", "shell", or "solid".
state
True if enabled, false if not.
Error
Returns 0 if successful, otherwise an error code.
