poIContourCtrl SetEnabled
Sets the dimension state, either enabled or disabled.
poIContourCtrl_handle SetEnabled pool state
HyperView Tcl Modify
This command sets the dimension state, either enabled or disabled.
- pool
- The pool from which to set the enable state.
- state
- True if enabled; false if disabled.
Error
Returns 0 if successful, otherwise an error code.
