poIContourCtrl SetDataComponent
Sets the data component for a given component.
poIContourCtrl_handle SetDataComponent dim comp_label
HyperView Tcl Modify
This command sets the data component for a given component.
Note: The component dimension must be enabled before setting.
dim
The dimension. Options include "node", "line", "shell", or "solid".
comp_label
The component label.
Error
Returns 0 if successful, otherwise an error code.
