poIContourCtrl SavePlotStyle
Captures the current contour controller settings and saves it with the given name.
poIContourCtrl_handle SavePlotStyle style_name
HyperView Tcl Modify
This command saves the current contour controller settings with the name specified. If no name is specified, a default name will be given for the plot style.
- style_name
- The name of the plot style.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetContourCtrlHandle contour_handle
contour_handle SavePlotStyle style_name
hwi CloseStack
Returns an error if the contour controller handle is invalid.
