poIContourCtrl SetResultSystem
Sets the result system ID.
poIContourCtrl_handle SetResultSystem system_id
HyperView Tcl Modify
This command sets the result system ID.
Note: Setting the result system is valid only for transformable data types, such as vector tensor.
system_id
The result system ID or one of the following special identifiers:
0
global
-1
analysis
-2
elemental
-3
tracking
Error
Returns 0 if successful, otherwise an error code.
