poIContourCtrl SetOffset
Sets the offset value of the contour.
poIContourCtrl_handle SetOffset value
HyperView Tcl Modify
This command sets the offset value of the contour.
value
Offset value to be set.
To set the offset value to 2:
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myModelName GetResultCtrlHandle myResultName
myResultName GetContourCtrlHandle myContourName
myContourName SetOffset 2
Error
Returns 0 if successful, or an error code (HW_InvalidHandle) if the handle used to invoke the method is no longer valid.
