poIContourCtrl SetAverageMode
Sets the method by which elemental results are averaged to nodes.
poIContourCtrl_handle SetAverageMode mode
HyperView Tcl Modify
This command specifies the method by which elemental results are averaged to nodes.
- mode
- Values can be: none, simple, maximum, minimum, advanced, difference, Max of corner, Min of corner, or Extreme of corner.
Error
None.
