Front View Swing Arm Length and Angle
Request Number: 50000160
Component | Unit | Comment |
1 (X): Left Wheel Front View Swing Arm Length | mm | The distance between the left wheel center and the left wheel center front
view instant center. It is calculated using the following equations:
2 (Y): Right Wheel Front View Swing Arm Length | mm | The distance between the right wheel center and the right wheel center front
3 (Z): Average Front View Swing Arm Length | mm | The mean of components 1 and 2. |
4 (RX): Left Wheel Front View Swing Arm Angle | deg | The front view angle between horizontal and the line connecting the left
wheel center and the left wheel center front view instant center. It is calculated
5 (RY): Right Wheel Front View Swing Arm Angle | deg | The front view angle between horizontal and the line connecting the right
wheel center and the right wheel center front view instant center. It is
6 (RZ): Average Front View Swing Arm Angle | deg | The mean of components 4 and 5. |
