Wheel Vertical Displacement and Vertical Force
Request Number: 50000000
Component | Unit | Comment |
1 (X): Left Wheel Center Vertical Displacement | mm | The global vertical displacement of the left wheel. The sign is positive when the wheel center moves up (jounce) and negative when the wheel center moves down (rebound). |
2 (Y): Right Wheel Center Vertical Displacement | mm | The global vertical displacement of the right wheel. The sign is positive when the wheel center moves up (jounce) and negative when the wheel center moves down (rebound). |
3 (Z): Average Wheel Center Vertical Displacement | mm | The mean of components 1 and 2. |
4 (RX): Left Wheel Center Vertical Force | N | The global vertical force between the left wheel part and the jack (vertical constraint) mechanism. |
5 (RY): Right Wheel Center Vertical Force | N | The global vertical force between the right wheel part and the jack (vertical constraint) mechanism. |
6 (RZ): Average Wheel Center Vertical Force | N | The mean of components 4 and 5. |
