Lateral Force Deflection
Request Number: 50000070
Component | Unit | Comment |
1 (X): Left Parallel Lateral Force Deflection | mm/kN | The left wheel center global lateral deflection due to parallel lateral
forces on the left and right tire patches or: 1000*(C(2,2) + C(2,4)*slr + C(2,8) + C(2,10)*slr) |
2 (Y): Right Parallel Lateral Force Deflection | mm/kN | The right wheel center global lateral deflection due to parallel lateral
forces on the left and right tire patches or: 1000*(C(8,2) + C(8,4)*slr + C(8,8) + C(8,10)*slr) |
3 (Z): Average Parallel Lateral Force Deflection | mm/kN | The mean of components 1 and 2. |
4 (RX): Left Converging Lateral Force Deflection | mm/kN | The left wheel center global lateral deflection due to converging lateral
forces on the left and right tire patches or: 1000*(C(2,2) + C(2,4)*slr - C(2,8) - C(2,10)*slr) |
5 (RY): Right Converging Lateral Force Deflection | mm/kN | The right wheel center global lateral deflection due to converging lateral
forces on the left and right tire patches or: 1000*(C(8,2) + C(8,4)*slr - C(8,8) - C(8,10)*slr) |
6 (RZ): Average converging Lateral Force Deflection | mm/kN | The mean of components 4 and 5 |
