Wheel Center Rotational Stiffnesses
Request Number: 50000060
Component | Unit | Comment |
1 (X): Left Wheel Center XX Stiffness | N-m/deg | The left wheel center single wheel rotational stiffness about the global
longitudinal axis
or: 1/C(4,4)/rtod/1000 |
2 (Y): Left Wheel Center YY Stiffness | N-m/deg | The left wheel center single wheel rotational stiffness about the global
lateral axis
or: 1/C(5,5)/rtod/1000 |
3 (Z): Left Wheel Center ZZ Stiffness | N-m/deg | The left wheel center single wheel rotational stiffness about the global
vertical axis
or: 1/C(6,6)/rtod/1000 |
4 (RX): Right Wheel Center XX Stiffness | N-m/deg | The right wheel center single wheel rotational stiffness about the global
longitudinal axis
or: 1/C(10,10)/rtod/1000 |
5 (RY): Right Wheel Center YY Stiffness | N-m/deg | The right wheel center single wheel rotational stiffness about the global
lateral axis
or: 1/C(11,11)/rtod/1000 |
6 (RZ): Right Wheel Center ZZ Stiffness | N-m/deg | The right wheel center single wheel rotational stiffness about the global
vertical axis
or: 1/C(12,12)/rtod/1000 |
