Roll, Tread Width, Tread Change, and Track Width
Request Number: 50000040
Component | Unit | Comment |
1 (X): Roll Angle | deg | The suspension roll angle and is defined as the arctan of the difference in
wheel center displacements divided by the difference in wheel center y coordinates
or: atan((rdisp-ldisp)/abs(rwcy-lwcy) The sign is positive when the right wheel is in jounce and the left wheel is in rebound as in a left turn. |
2 (Y): Tread Width | mm | The distance between the left and right tire patch points. |
3 (Z): Tread Change | mm/m | The change in tread width due to a change in wheel displacement and is defined:
4 (RX): Track Width | mm | The difference in wheel center y coordinates. |
