attachmentcontrols
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- connectouterlayer
- The way to connect to the hole for config 1.
- definedentity
- True if the entity is defined, false otherwise.
- elemtype
- The element type name for config 1.
- engname
- The engineering name.
- findhole
- 0 - Do not find a hole
- holeandwasher
- The option to fill hole or use washer elements for config 2.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- maxdia
- The maximum diameter for finding a hole when findhole is 1.
- mindia
- The minimum diameter for finding a hole when findhole is 1.
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
Version History
2020
