designpoints
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- attributesmax
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- designpointstrucelemid
- The ID of the structural property.
- entityids
- The IDs of the entities.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- panellength
- The calculated panel length if the design point contains panel entities.
- panelradius
- The calculated panel radius if the design point contains panel entities.
- panelwidth
- The calculated panel width if the design point contains panel entities.
- position
- The coordinates of the location.
- projectentityids
- The IDs of the projection entities.
- system
- The ID of the system.
Version History
2019.1
2020 - Added new data names activesuppressed, color_rgb, name, outputsuppressed, panellength, panelradius, panelwidth and position.
