designpointsets
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
5 - Rivet
7 - Spring
30 - Panel metallic
31 - Panel composite
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
designpointids
The IDs of the associated designpoint entities.
Type: entity array
designpointmethodids
The IDs of the associated designpointmethod entities.
Type: entity array
evalPolicy
The evaluation policy:
perLocationMultipleEval
perLocationSingleEval
Type: string
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
loadcaseids
A combination of result file ID, load case ID and time step ID separated by -. Multiple combinations are separated by a comma.
Type: entity array
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
Version History
2019.1
2020 - Added new data name color_rgb. Added new config values 30 and 31.
