elements
Unless otherwise specified, data names are accessible in level 3 only.
The following data names are only available for "core" solver templates routinely maintained by Altair:
- cogx
- The x center-of-gravity for the element. This takes into account the thickness and mass of the element.
- cogy
- The y center-of-gravity for the element. This takes into account the thickness and mass of the element.
- cogz
- The z center-of-gravity for the element. This takes into account the thickness and mass of the element.
- elementalxaxis
- The x-component of the element orientation direction for 2D elements.
- elementalyaxis
- The y-component of the element orientation direction for 2D elements.
- elementalzaxis
- The z-component of the element orientation direction for 2D elements.
- Ixx
- The Ixx component of the mass moment of inertia for the element. This is calculated about the global origin (0,0,0).
- Ixxcog
- The Ixx component of the mass moment of inertia for the element. This is calculated about the element COG.
- Iyy
- The Iyy component of the mass moment of inertia for the element. This is calculated about the global origin (0,0,0).
- Iyycog
- The Iyy component of the mass moment of inertia for the element. This is calculated about the element COG.
- Izz
- The Izz component of the mass moment of inertia for the element. This is calculated about the global origin (0,0,0).
- Izzcog
- The Izz component of the mass moment of inertia for the element. This is calculated about the element COG.
- Ixy
- The Ixy component of the mass moment of inertia for the element. This is calculated about the global origin (0,0,0).
- Ixycog
- The Ixy component of the mass moment of inertia for the element. This is calculated about the element COG.
- Ixz
- The Ixz component of the mass moment of inertia for the element. This is calculated about the global origin (0,0,0).
- Ixzcog
- The Ixz component of the mass moment of inertia for the element. This is calculated about the element COG.
- Iyz
- The Iyz component of the mass moment of inertia for the element. This is calculated about the global origin (0,0,0).
- Iyzcog
- The Iyz component of the mass moment of inertia for the element. This is calculated about the element COG.
- mass
- The summed total mass of the element. This takes into account both structuralmass and nonstructuralmass.
- material
- The ID of the material for the element. This takes into account the property, component or component's property to get this value.
- nonstructuralmass
- The summed nonstructural mass of the element.
- plylist
- The list of ply IDs or the stacking sequence for the element.
- plylistmax
- The number of ply IDs in the stack sequence for the element.
- principalaxis1
- The x, y and z components of the first principal axis for the element. This is calculated about the global origin (0,0,0).
- principalaxis1cog
- The x, y and z components of the first principal axis for the element. This is calculated about the component COG.
- principalaxis2
- The x, y and z components of the second principal axis for the element. This is calculated about the global origin (0,0,0).
- principalaxis2cog
- The x, y and z components of the second principal axis for the element. This is calculated about the component COG.
- principalaxis3
- The x, y and z components of the third principal axis for the element. This is calculated about the global origin (0,0,0).
- principalaxis3cog
- The x, y and z components of the third principal axis for the element. This is calculated about the component COG.
- refx
- The x-component of material orientation direction for 2D or 3D elements.
- refy
- The y-component of material orientation direction for 2D or 3D elements.
- refz
- The z-component of material orientation direction for 2D or 3D elements.
- structuralmass
- The summed structural mass of the element.
- thickness
- The thickness of the element. This only takes into account the thickness of the property assigned to the element.
LS-DYNA Specific Data Names
The following data names are only available for LS-DYNA, or have specific behavior for LS-DYNA.
- nonstructuralmass
- The summed nonstructural mass added through *ELEMENT_MASS_PART_SET, *ELEMENT_MASS_PART or NSM in *SECTION.
- structuralmass
- The summed structural mass of the elements in the component.
Version History
2019 - Added new data names plyidlist, plyidlistmax, refx, refy and refz.
2019.1 - Added new data names elementalxaxis, elementalyaxis, and elementalzaxis.
