opticonstraints
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
bound
The bound type.
0 - lower
1 - upper
2 - both
Type: integer
configname
The solver name of the entity. Valid for hm_getvalue query only.
Type: string
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
loadsteplist
A pointer to the loadstep IDs.
Type: pointer(value is loadstep ID)
loadsteplistmax
The number of assigned loadsteps.
Type: integer
locbuck
Lower bound of a local buckling eigenvalue response. The local buckling zone can be defined using DOPTPRM, BKLOCAL2 and DOPTPRM, BKLOCAL1. The LOCBUCK field can be used to specify the lower bound of the local buckling eigenvalue response. If the specified response is determined to be a local buckling mode, the LOCBUCK lower bound is utilized, otherwise, the LBOUND lower bound value is used for the response.
Type: double
lowerbound
Lower bound value.
Type: double
lowerboundtoggle
State (on=1, off=0) of the lower bound toggle.
Type: integer
loweroption
Lower bound options:
0 - Blank
1 - Lower bound value (real)
2 - Lower bound value using table ID (entity)
Type: integer
lowertableid
Lower bound on response or table identification number of a TABLEDi entry that specifies the lower bound as function of a loading frequency.
Type: entity
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
responseid
The ID of the assigned response.
Type: integer
upperbound
Upper bound value.
Type: double
upperboundtoggle
State (on=1, off=0) of the upper bound toggle.
Type: integer
upperoption
Upper bound options:
0 - Blank
Type: integer
uppertableid
Upper bound on response or table identification number of a TABLEDi entry that specifies the upper bound as function of a loading frequency.
Type: entity
Version History
2019 - Added new data names locbuck, loweroption, lowertableid, upperoption and uppertableid.
