terminations
Unless otherwise specified, data names are accessible in level 3 only.
- actim
- The termination activation time. Valid for config 102.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- atime
- The termination activation time. Valid for config 103.
- attributesmax
- The number of attributes owned by this entity.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- cid
- The termination contact ID. No CONTACT_2D allowed. Valid for config 102.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- dof
- The termination option to consider only the force magnitude in the x, y, or z global directions corresponding to DOF 1,2, and 3 respectively. Valid for config 102.
- dur
- The termination time duration of the null resultant force prior to termination. Valid for config 102.
- entityId
- The termination part ID or part set ID. Valid for config 104 and 105.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- lcid
- The termination load curve ID. Valid for config 103.
- maxc
- The termination maximum (most positive) displacement. Must be greater than minc. Valid for config 101.
- minc
- The termination minimum (most negative) displacement. Must be less than maxc. Valid for config 101.
- name
- The name of the entity.
- nds
- The number of elements that must be deleted for the specified part IDs before an error termination occurs. Valid for config 104 and 105.
- nid
- The termination node ID. Valid for config 106.
- nmaxc
- The termination maximum (most positive) coordinate. Must be greater than nminc. Valid for config 106.
- nminc
- The termination minimum (most negative) coordinate. Must be less than nmaxc. Valid for config 106.
- nstop
- The termination stop criterion. Valid for config 106.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- pid
- The termination part ID of the rigid body. Valid for config 101.
- stop
- The termination stop criterion. Valid for config 101.
- swid
- The termination ID of LS-DYNA*SENSOR_SWITCH which will terminate the calculation when its condition is met. Only one is allowed. If more than one is defined, only the last one is effective. Valid for config 107.
- thres
- The termination threshold. Valid for config 102.
Version History
2019
2020 - Added new data name color_rgb.
